Home :: Axles & Parts :: 40mm :: Axle Hub Spacer Kit (Alloy) 8pcs Suit 40mm Axle (Extend axle shaft up to 37.5mm per side)
Alloy Axle Hub Spacer Kit
8pcs comprising of:
2pcs 2.5mm Thick
2pcs 5mm Thick
2pcs 10mm Thick
2pcs 20mm Thick
Allows you to space your rear hubs further out than the end of your axle shaft.  By adding each size spacer or a combination of some/all you can extend the hub out from 2.5mm up to 37.5mm per side (2.5, 5mm, 7.5mm, 10mm, 12.5mm, 15mm, 17.5mm, 20mm, 22.5mm, 25mm, 27.5mm, 30mm, 32.5mm, 35mm, 37.5mm)
Suits axle diameter: 40mm
SKU AHSKS1
