Home :: Airboxes, Filters & Parts :: Filters :: Air Filter Upgrade PACK suits GX270 GX390 Style Honda & Clone 4-Stroke Engine
NEW BASIC INLET UPGRADE KIT FOR GX270-GX390
This fantastic pack includes all the gear you'll need to increase horsepower via your inlet breathing. Comes with venturi, air filter, choke bracket and upgraded fuel jet to ensure no lean-out conditions.
DON'T INSTALL AN AFTERMARKET FILTER WITHOUT ATTENDING TO YOUR FUEL JET! YOUR ENGINE WILL LEAN OUT AND SEIZE.
Our kits come complete with the correct fuel jet to ensure you don't have issues with engine failures from installing an air filter kit.
-Air Filter (Filter neck ID approx 62mm.)
- Venturi Adaptor [If you are looking to adapt this item to another filter or engine, stud spacing is 52mm centre to centre, 6mm studs. Centre of venturi has a hole 30mm diameter. Outer diameter is 62mm.]
- Choke Bracket - 115 Fuel Jet (ensure you don't run your engine dangerously lean and cause serious damage when fitting an aftermarket air filter)
Save about $20 by buying the kit in this form, rather than all the individual items.
TappetCoverBreathergGuide
SKU FAUKC39
Regular price: $104.36
Price with FREE DELIVERY: $99.95
