Home :: Engines, Carbs & Parts :: Engines :: Adjustable Pushrod Push Rod Length Measuring Tool - Single Unit - Suit GX240 GX270 133mm-146mm
*DO NOT RUN ENGINE WITH THIS ITEM INSTALLED
USE WITH STOCK SPRINGS
Adjustable push rod tool - designed to determine the correct length push rod required to get your valve train geometry correct.
Adjusts from 133mm-146mm
Price is for a single unit.
SUITS GX240 & GX270
PushrodLengthGuide
SKU EPRMT2
