Home :: Engines, Carbs & Parts :: Engines :: Adjustable Pushrod Push Rod Length Measuring Tool - Single Unit - Suit GX160 & GX200 128mm-142mm
*DO NOT RUN ENGINE WITH THIS ITEM INSTALLED
USE WITH STOCK SPRINGS
Adjustable push rod tool - designed to determine the correct length push rod required to get your valve train geometry correct.
Adjusts from 128mm-142mm
Price is for a single unit.
SUITS GX200 & GX160 (6.3mm diameter rod)
PushrodLengthGuide
SKU EPRMT1
