Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Adapter Adaptor to convert to GX390 Carb suits GX160/200 & Clone 4-Stroke Engine CPR OHV 6.5hp 192cc (Can be used with GX270 or GX240 carbs with additonal fittings - see description)
Adapter for GX200/160 and clones.
This part will convert your GX200/160 intake to suit Larger GX390 Carburettors.
Designed to mount GX390 fitment carbs to GX200 and predator/clones on 15 degree engine mounts.
GX270 or GX240 carbs can be used but require the GAIC27 Gasket and the EIPC27 insulator.
Pulse fitting should face upward or alternatively if no pulse is required you can use the included plug to block off the hole.
*Note - on some very large/long duration cams the vacuum pulse from the inlet manifold may be too weak - in those cases you may need to plumb a pulse fitting into the valve cover or crank case.
SKU ECA390
$26.95
