Home :: Axles & Parts :: 50mm Slimline Bearing High Speed PREMIUM C4 Clearance Low Friction (80mm OD)
50mm Slimline Low Friction Race Bearing complete with grub screws.
(*NOTE: These bearings WILL fit CPR 40mm housings)
A (outer diameter) = 80mm
B (Sleeve protrusion) = 18mm
C (width of bearing) = 18mm
D (Sleeve protrusion) = 0mm
E (Locator) = NO
G (Inner diameter / axle shaft size) = 50mm
Suits 50mm Axles with 80mm ID hangers (Suits CPR 40mm Bearing Holders/Hangers).
SKU ABPQ50SB
