Home :: Axles & Parts :: 40mm Slimline Bearing High Speed Low Friction Rubber Sealed
40mm Slimline Low Friction Race Bearing complete with grub screws.
(*NOTE: These bearings do not fit CPR  40mm housings)
A (outer diameter) = 80mm
B (Sleeve protrusion) = 16mm
C (width of bearing) = 18mm
D (Sleeve protrusion) = 0mm
E (Locator) = NO
F (Sleeve outer diameter) = 51.5mm
G (Inner diameter / axle shaft size) = 40mm
Suits 40mm Axles.
SKU ABPQ40SB
