Home :: Axles & Parts :: 40mm :: 40mm BASE Axle Kit RED (no shaft no disc and hub)
COMPLETE 40mm AXLE ASSEMBLY Less Shaft.  EVERYTHING you need to bolt-on and go - including ALL the nuts and bolts WITH ANODISED COUNTERSUNK WASHERS!  This is a dream price!
Not included.  Suits Axle Diameter: 40mm
SKU AX4BR
