Home :: Engines, Carbs & Parts :: Engines :: 4-Stroke Engine Torini 212cc Clubmaxx SEALED Base Engine for 4SS (no clutch or muffler included)
The NEW TORINI Clubmaxx performance pre-built engine has just arrived.
LOOKING FOR THE Torini Clubmaxx OWNERS MANUAL?  Click Here
This is a 212cc governor-less predator-style 4-Stroke engine with aftermarket Flywheel & Conrod fitted (similar to our stage 1 race engine) but is homologated and sealed for us in the new KA 4SS class.
This is the base engine which includes the air filter and sock.  You will also need the homologated muffler, homologated clutch, a mount and a chain guard to complete your engine.  These can be found in the 'Related Products' at the bottom of this listing.
The Torini TC210 Engine comes out of the box with four Torini engine seals ready to race. Simply attach your throttle cable and fuel line and you're good to go.
The engine is shipped without oil. Oil must be added before starting.
We recommend first running in your engine with Torini 4S Run In Oil and then switching over to Torini 4S Racing Oil to ensure the highest possible protection and performance is achieved.
  • Karting Australia homologated engine - No. 109H
  • Key internal engine components ultrasonically cleaned before assembly
  • Hand built in Australia by Austech Industries Pty Ltd using local and imported high quality forged and billet components, suitable for both single engine sprint racing and twin engine endurance racing
SPECIFICATIONS
Engine Type: Single Cylinder, 4-Stroke, Forced Air Cooling, OHV25°
Bore x Stroke (mm) 70 X 55
Displacement (cc): 212
Engine Oil Capacity (ml): 550ml
Starting Mode: Pull Start
Lubrication Mode: Splash
Cooling System: Forced Air Cooling
Fuel: Premium Unleaded
Ignition System: T.C.I. Digital Ignition Limited to 6100rpm
Horse Power: 9.9Hp / 7.4Kw
Torque: 15Nm
Carburettor: 19mm Venturi Butterfly Type (P/N: TC25SEK)
Carburettor Manifold: CNC Billet Type (P/N: TC25046)
Muffler: RLV - Model TC25060 (NOT INCLUDED)
Clutch: Noram - TC-GEL19219 (NOT INCLUDED)
Spark Plug: NGK - BPR6ES
Timing: 25 Degrees
Compression: 8.5 to 1
Oil: P/N: TRO1031 - Engine Run in Oil (NOT INCLUDED)
P/N: TRO1000 - Engine Racing Oil (NOT INCLUDED)
SKU ENCLTOR
Price with FREE DELIVERY: $899.00
