Home :: Engines, Carbs & Parts :: Engines :: 4-Stroke Engine LIFAN OHV 10hp 192cc Complete + Upgrade & Governor Removal (GT Race 12T Clutch)
THIS MODEL INCLUDES OUR GT-RACE 12T CLUTCH - FULLY ADJUSTABLE.  You can read more about the GT clutch by CLICKING HERE
Our NEW performance pre-built engine has just arrived.  With the complete upgrade kit fitted (inlet & exhaust) with all panels and external fuel pump, this engine is ready to race out of the box.   Even the governor has been removed for your convenience.
Are you looking for a simple & easy solution to powering a racing go kart?  Ideal starting point for racing use, our CPR Honda Clone engine is one of the best built, most reliable available in Australia.  We buy the best quality clone available today with quality automotive grade components inside.  It comes complete, ready to run with throttle cable and clutch already attached.  All you need to do is mount it to your frame - can be easily adapted to any 2-stroke mount with an adaptor plate.
CPR Engines will keep you running. All Lifan engines are Industrial Grade and feature cast iron sleeves, automotive grade rods, pistons, rings, crankshafts, valve and valve springs.The Lifan Overhead Valve (OHV) design provides better fuel efficiency, quieter operation, and longer life. The Engine is ideal for go kart use.  The Overhead Valve (OHV) design provides fuel efficiency, quiet operation, and a long life. The engine features a horizontal-shaft design for go-kart use.
68 mm x 54 mm bore/stroke
Horizontal output shaft
Force-Air Cooled
THIS MODEL INCLUDES OUR GT-RACE 12T #35 Pitch CLUTCH - FULLY ADJUSTABLE.  You can read more about the GT clutch by CLICKING HERE
Throttle cable clamp
1m Fuel Line
Fuel Filter
GTClutchChoiceGuide
SKU ENCLST1_12GT
Regular price: $1989.86
Price with FREE DELIVERY: $699.00
