Home :: Engines, Carbs & Parts :: Engines :: 4-Stroke Engine LIFAN OHV 10hp 192cc Complete + Upgrade & Governor Removal (18T Clutch)
Our NEW performance pre-built engine has just arrived. With the complete upgrade kit fitted (inlet & exhaust) with all panels and external fuel pump, this engine is ready to use on the race-track out of the box. Even the governor has been removed for your convenience.
*NOTE This engine is deisgned for recreational race-track use. Non-GT engines are not designed for sustained high-rpm use. If you are racing at a competitive level or you are using the engine on a speedway/oval, you may experience rod failure due to the nature of tuning the gear-set to the optimal range based on maximum attained RPM. We recommend our GT range of race engines for those planning on using their engine in competitive environments.
Are you looking for a simple & easy solution to powering a racing go kart?  Ideal starting point for racing use, our CPR Honda Clone engine is one of the best built, most reliable available in Australia.  We buy the best quality clone available today with quality automotive grade components inside.  It comes complete, ready to run with throttle cable and clutch already attached.  All you need to do is mount it to your frame - can be easily adapted to any 2-stroke mount with an adaptor plate.
CPR Engines will keep you running. All Lifan engines are Industrial Grade and feature cast iron sleeves, automotive grade rods, pistons, rings, crankshafts, valve and valve springs.The Lifan Overhead Valve (OHV) design provides better fuel efficiency, quieter operation, and longer life. The Engine is ideal for go kart use.  The Overhead Valve (OHV) design provides fuel efficiency, quiet operation, and a long life. The engine features a horizontal-shaft design for go-kart use.
68 mm x 54 mm bore/stroke
Horizontal output shaft
Force-Air Cooled
This unit is supplied with
Throttle cable clamp
1m Fuel Line
Fuel Filter
Need an owners manual?  Download one by clicking here.
SKU ENCLST1_18
Regular price: $1872.55
Price with FREE DELIVERY: $599.00
