Home :: Engines, Carbs & Parts :: Engines :: 4-Stroke Engine Avalon Fun Kart Club Legal 192cc Complete + Upgrade & Governor Removal (12T Clutch)
This is the new AVALON FUN KART CLUB CPR Engine.
INCLUDES MUFFLER TIP (not pictured on engine, but a separate picture of the muffler is included in the detailed image section)
Designed for class legal, safe racing at Avalon Fun Kart Club, this engine includes a standard boxed protected air filter and full length fully enclosed chain and sprocket guard.  Guard, filter, and full length guard are included and pre-drilled but will need to be installed (4 bolts).
Our NEW performance pre-built engine has just arrived.  With the complete upgrade kit fitted (inlet & exhaust) with all panels and external fuel pump, this engine is ready to race out of the box.   Even the governor has been removed for your convenience.
Our premium quality 196cc honda-clone engine (no plastic gears inside)
  • Throttle Cable fitted with terminator clamp ready to connect to your pedal
  • SR Clutch fitted ready to connect to your chain
  • Fuel pump fitted ready to connect to your fuel tank
  • Sports muffler
  • External aluminium top-plate and professional throttle linkage system
  • Professional removal of governor and oil sensors
  • Pull Starter
  • Fully enclosed nylon transmission guard (chain and sprocket cover)
Are you looking for a simple & easy solution to powering a racing go kart?  Ideal starting point for racing use, our CPR Honda Clone engine is one of the best built, most reliable available in Australia.  We buy the best quality clone available today with quality automotive grade components inside.  It comes complete, ready to run with throttle cable and clutch already attached.  All you need to do is mount it to your frame - can be easily adapted to any 2-stroke mount with an adapter adaptor plate.
CPR Engines will keep you running. All Lifan engines are Industrial Grade and feature cast iron sleeves, automotive grade rods, pistons, rings, crankshafts, valve and valve springs.The Lifan Overhead Valve (OHV) design provides better fuel efficiency, quieter operation, and longer life. The Engine is ideal for go kart use.  The Overhead Valve (OHV) design provides fuel efficiency, quiet operation, and a long life. The engine features a horizontal-shaft design for go-kart use.
68 mm x 54 mm bore/stroke
Horizontal output shaft
Force-Air Cooled
This unit is supplied with
Throttle cable clamp
1m Fuel Line
Fuel Filter
SKU ENCAVA
Regular price: $1958.82
Price with FREE DELIVERY: $649.00
