Home :: Engines, Carbs & Parts :: Engines :: 4-Stroke Engine 10+hp 192cc COMPETITION GT + Ally Flywheel Billet Conrod 26lb Springs Chromoly Push-rods (12T Clutch)
NOTE: This engine is designed for competitive racing and sustained high-rpm use. However, keep in mind that all engines have a lifespan, and due to the nature of high-rpm use and metal fatigue/wear, all race engines will eventually fail. The speed at which the failure occurs depends entirely on the responsible use of the equipment. Perform frequent oil changes and set a realistic RPM limit to preserve your enjoyment for longer.
JUST ARRIVED!
OUR NEW COMPETITION GT ENGINE IS HERE!
DESIGNED FOR THE ULTIMATE IN COST EFFECTIVE PARITY RACING our new "Competition GT" engine offers unrivaled value for money and provides the ultimate in fair racing at the absolute best price in Australia.
THIS ENGINE INCLUDES ALUMINIUM FLYWHEEL FOR COMPLETE SAFETY AT HIGH RPM!
THIS ENGINE IS NOT RPM LIMITED.
And there's more, we've re-fitted the stock springs with high performance 26lb springs to ensure valve float will not damage your new engine's head.
Are you looking for a simple & easy solution to powering a go kart?  Ideal starting point for racing or recreational use, our CPR GT Honda Clone engine is one of the best built, most reliable available in Australia.  We buy the best quality clone available today with quality automotive grade components inside.  It comes complete, ready to run with throttle cable and clutch already attached.  All you need to do is mount it to your frame - can be easily adapted to any 2-stroke mount with an adapter adaptor plate.
Planning on racing your engine later?  Don't get stuck with a poor flowing head, start with our engine as a base and ensure you have the best flowing head on the track for all box-stock categories where porting is not allowed.  If you're going to port anyway, why not start with a better design so your work is even more rewarding?
CPR GT engines are Industrial Grade and feature cast iron sleeves, automotive grade rods, pistons, rings, crankshafts, valve and valve springs.The Overhead Valve (OHV) design provides better fuel efficiency, quieter operation, and longer life. The Engine is ideal for go kart use.  The Overhead Valve (OHV) design provides fuel efficiency, quiet operation, and a long life. The engine features a horizontal-shaft design for go-kart use.
68 mm x 54 mm bore/stroke
Horizontal output shaft
Force-Air Cooled
CHROMOLY PUSH RODS INSTALLED
26LB VALVE SPRINGS INSTALLED
ALUMINIUM FLYWHEEL FITTED
PROFESSIONALLY INSPECTED AND REASSEMBLED BY OUR HONDA TECHNICIAN (crowned by Honda as Australias #1 Honda technician)
This unit is supplied with
Throttle cable clamp
1m Fuel Line
Fuel Filter
A comprehensive competition package.  Go racing reliably at the best value in Australia!
SKU ENCLGT_12
Regular price: $10153.50
Price with FREE DELIVERY: $1249.00
