Home :: Axles & Parts :: 30mm Slimline Bearing High Speed Low Friction Rubber Sealed
30mm Slimline Low Friction Race Bearing complete with grub screws.
30mm ID & 62mm OD
A (outer diameter) = 62mm
B (Sleeve protrusion) = 13mm
C (width of bearing) = 16mm
D (Sleeve protrusion) = 0mm
E (Locator) = NO
F (Sleeve outer diameter) = 41mm
G (Inner diameter / axle shaft size) = 30mm
Suits 30mm Axles.
SKU ABPQ30SB
