Home :: Axles & Parts :: 30mm Bearing SINGLE High Speed Low Friction Rubber Sealed
30mm Low Friction Race Bearing complete with grub screws.
30mm ID & 62mm OD
A (outer diameter) = 62mm
B (Sleeve protrusion) = 11mm
C (width of bearing) = 19mm
D (Sleeve protrusion) = 7mm
E (Locator) = YES
F (Sleeve outer diameter) = 42.5mm
G (Inner diameter / axle shaft size) = 30mm
Suits 30mm Axles.
SKU ABPQ30
