Home :: Axles & Parts :: 25mm Bearing SINGLE High Speed Low Friction Slimline
25mm Slimline Low Friction Race Bearing (sheilded) complete with grub screws.
25mm ID & 52mm OD
Dimensions:
A (outer diameter) = 52mm
B (Sleeve protrusion) = 11.5mm
C (width of bearing) = 17mm
D (Sleeve protrusion) = 0mm
E (Locator) = NO
F (Sleeve outer diameter) = 34mm
G (Inner diameter / axle shaft size) = 25mm
Suits 25mm Axles.
SKU ABPQ251SB
