Home :: Axles & Parts :: 25mm Bearing SINGLE High Speed Low Friction Rubber Sealed
1x 25mm Low Friction Race Bearing complete with grub screws.
25mm ID & 52mm OD
Dimensions:
A (outer diameter) = 52mm
B (Sleeve protrusion) = 11mm
C (width of bearing) = 17mm
D (Sleeve protrusion) = 5mm
E (Locator) = YES
F (Sleeve outer diameter) = 34mm
G (Inner diameter / axle shaft size) = 25mm
Suits 25mm Axles.
SKU ABPQ251
