Home :: Engines, Carbs & Parts :: Engines :: 2-Stroke Engine PRD RK100 18hp Electric Start 10T 219p Clutch COMPLETE READY-TO-RACE PACKAGE
We've received a scoop purchase of these super-reliable, low cost high quality engines - they're cheap because they were a clearance deal!  You get awesome power in a complete electric start package - turnkey, with everything from muffler through to starter button and battery included!  Even a clutch is included and fitted to the unit!  AMAZING VALUE.
This 18hp engine is comparable to the KT100S and can be raced against it quite evenly.
If you've got a non-electric start KT100S and want to race the guys with an electric start model, this is the perfect way to do it!  A purpose built race engine - not a suped up pump motor!
Perfect for the local track, recreation, or the backyard speedway!
Capacity 98cc
Horse Power 18HP
Restricted Horse Power N/A
Bore 49.92mm
Stroke 50.00mm
Piston Aluminium
Ring Type Dykes
Cooling System Air Cooled
Radiator N/A
Air Admission Piston Port
Reed Petals N/A
Reed Manifold N/A
Head Volume 10cc
Conrod Forged 100mm Medium
Ignition PRD #7 Magneto
Spark Plug Cap PRD Resistor
Carburettor Walbro WB42 W/Choke
Exhaust Straight Coned / Adjustable Length
Starting System Electric Start
Drive System Centrifugal Steel Clutch
Airbox Silver 23mm
Air Filter Internal Filter
Battery Yuasa
Cylinder Liner Cast Iron
Ports Cast
Power Valve N/A
Rebuild Time Top End approx 15hrs
Rebuild Time Bottom End approx 30hrs
Max RPM 14500-15000 (recommended)
Included in the kit Engine
10T 219p Clutch
Carburettor
Carburettor Spacer Block
Carburettor Spacer Gaskets
Airbox
Airbox Adaptor
Air Filter Red Short
Airbox Clamp
Spark Plug
Exhaust Gasket
Exhaust Header
Exhaust Flex Spacer
Exhaust Flex Sealer
Exhaust Springs
Exhaust Muffler
Wire Loom
Starter Button
Off Button
Switch Bracket
Battery Bracket
Battery
RECOMMEND FUEL:OIL RATIO 16:1
RECOMMEND CARB BASE TUNE 1+1/2 LOW & 1/4 HIGH
SKU ENPRDES
