Home :: Clutches :: 19mm Crankshaft Clutch Installation Fit Mount Kit (suit GX200 / GX160) (Special Washer, Bolt, and Spacer)
1x 19mm Crankshaft Spacer (suit GX200) - goes between the clutch and the engine so your clutch doesn't foul on the crankcase cover which can cause failure of the clutch and or damage and injury.
1x Clutch Retaining Washer (extra thick 3mm and large OD 29mm) - goes on the end of the clutch to ensure the clutch cannot slide off the end of the crankshaft  which can cause failure of the clutch and or damage and injury.
1x Clutch Retaining Bolt to suit 19mm 3/4" standard GX200 style crankshaft - secures the clutch to the crankshaft to ensure the clutch cannot slide off the end of the crankshaft  which can cause failure of the clutch and or damage and injury.
** DO NOT USE A STANDARD M8 BOLT IN THE END OF YOUR CRANKSHAFT!   The bolt included in this pack is designed to fit the specialised thread in your crankshaft - using a standard M8 bolt will strip the thread and result in the need to remove the crankshaft and re-install a new one which can be a costly and heartbreaking mistake.
NEW.  Click the condition meter to learn more about used items.
SKU CLIKC1
Regular price: $14.41
Price with FREE DELIVERY: $9.95
