Home :: Clutches :: 19.05mm 3/4inch to 25.4mm 1inch Crankshaft Converter Sleeve Adapter daptor AKit
3/4inch to 1inch drive converter kit
Designed to convert 3/4" shafts (such as those on GX200 engines) to the larger 1inch 25.4mm shaft size to accept larger stronger torque converters or other 1" clutches.
Length of sleeve approx. 75mm
Length of key approx 50mm
(designed to be cut to size to suit shaft application)
Kit includes sleeve and key.
NEW.  Click the condition meter to learn more about used items.
3/4 to 1 crankshaft adapter adaptor
SKU ECSC34
