(*Note picture of 6.5hp engine for reference purpose only - does not include engine or side plate/chain cover, also note the muffler header included is the free-flow model pictured separately and does not match the picture within the bundle main picture)
INCLUDES LARGER FUEL JET TO AVOID LEAN-OUT AND SEIZURE OF YOUR ENGINE
BRAND NEW. NEW MODEL - now with Throttle cable!
*We recommend the use of our BILLET FLYWHEEL when upgrading your engine for safety and club track rule adherance.
Complete upgrade pack to suit our CPR 9HP and 13hp (GX270 and GX390) honda clone engines. Make up to 17hp by bolting onto a 13hp engine. (Results may be less depending on quality of engine, or if you're starting with a 9hp engine then the approximate power level will be around 13hp)
This kit replaces Air Intake system, upgrades the fuel system to an external tank and high flow fuel pump, upgrades exhaust system and includes all springs and connectors necessary for a complete change-over. Also includes polished aluminium professionally welded mount plate. Your engine will look fantastic after this upgrade!
*NOTE* You will not be able to bolt your stock metal tank to the engine after this upgrade, this uprgrade is designed to relocate the tank elsewhere. You can, if required, create new mounts and screw them to the top plate to mount the stock tank back on the plate if required but there are no pre-drilled holes or brackets in the kit/plate to support this out of the box.
Bolt-on complete fitment for 9HP or 13HP GX270/GX390 engines.
Components included:
- Polished Aluminium Top Plate
- Complete Remote Linkage kit (disconnects governor for high RPM work and added power)
- External Fuel Pump
- 120 Fuel Jet
- Full set of 3x inlet gaskets
- RLV Premium Race Muffler Header pipe and tip
- Exhaust Gasket
-- Pod-Style air filter
- - Billet Aluminium High-Flow Venturi
- 2m Fuel Line (0.5m for vac fittings)
- Race Fuel Filter
- Throttle cable
- Throttle Cable Terminator
- Assembly instructions online (electronic version on our Forum - you can view the assembly guide here:
https://cutpriceracing.com.au/store/ENUCL39-GX390-Hop-Up-Kit-Installation-Guide/
Get more power, easily!
