Race Spec Exhaust Header Pipe.
Proven race winning header & RLV muffler combo.
ADD EXTRA HP!
This item will significantly improve breathing and heat transfer. This item is currently being used on competitive karts nationally and in the USA.
Flange suits GX200 measurements - approx 45mm stud to stud on the exhaust port of the head.
Pipe ID is 24.5mm at the flange, steps up to ID 30.5mm where the tip goes on.
OD is 27mm at the flange and OD is 34mm where the tip goes on.
Dimensions as per last detailed image:
A = ~200mm
B = ~300mm
C = ~340mm (overall length in a straight line from header pipe end to head mating flange)
OVERALL LENGTH INCLUDING MUFFLER TIP (not shown) = ~460mm
