Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Gasket Set Air Inlet Manifold, Vacuum Sandwich, Carb & Venturi suits GX200 6.5hp and Clone engines
Full 3pcs Gasket Set Air Inlet Manifold, Vacuum Sandwich, Carb & Venturi suits GX200 6.5hp and Clone engines.
This gasket kit gives you 100% perfect seals when doing an external fuel pump vacuum tap conversion, and an aftermarket fuel filter upgrade.
for the orientation of the gaskets CLICK HERE
SKU GSAIC1
Price with FREE DELIVERY: $9.95
Vacuum Manifold Sandwich Insulator for External Fuel Pump GX160/200 and Clone
Air Filter suits Upgrade Kit for 4-Stroke Engine Vacuum Manifold Sandwich Insulator for External Fuel Pump GX160/200 and Clone
$26.95
$34.95
Air Filter Upgrade PACK suits GX200 Style 6.5hp Honda & Clone 4-Stroke Engine
$79.95
