Home :: Engines, Carbs & Parts :: Mounts :: Engine Mount Billet Fully Adjustable Centre to Centre Rails Ideal for 4-Stroke GX200 V2
***NOTE:  Picture #1 is of EMTA01 but is used for dimensional representation.  This item is pictured correctly in all other pictures***
Fully Adjustable Anodised Billet engine mounting system.  (lateral position adjustment)
15 degree angled.
Suits 90 or 92mm rail centre to centre and 28-32mm tubes.
The perfect mount for switching to 4-stroke engines (threaded holes designed for Honda GX200/160 and clone engines as well as Briggs/Vangard ~200cc 6-6.5hp engines including World Formula, Animal etc.
Complete top, middle and bottom brackets with all required bolts.
Dimensions:
A (Side edge to outer hole centre) - ~25mm
B (outer hole centre to centre hole centre) - ~25mm
C (centre hole centre to inner hole centre) - ~25mm
D (Side edge to inner hole centre) - ~25mm
E (Side edge to edge of slot) - ~ 24mm
F (Slot length) - ~61mm
*Note both top and bottom plates are symettrical
G (Slot edge to centre of inner engine rail) ~10mm
GX200 base is 162mm x 78mm hole centre to hole centre.
SKU EMTA02
Price with FREE DELIVERY: $299.90
