COMPLETE KIT WITH EVERYTHING YOU NEED INCLUDING CRANKSHAFT KEY! CPR's new GT-RACE series selects our performance components to suit competitive racing go-karts for track competition purposes. Uncompromising quality at the most affordable price. Make no mistake though, CPR GT-RACE products are premium quality. WHY ARE THEY SO CHEAP? Well we buy direct from the manufacturer in bulk, not via a local distributor and that means you SAVE HEAPS! If you're looking for an advantage on the track and are not interested in paying huge prices then try our GT-RACE range and join the growing community of affordably competitive racers today!. 35 Pitch RACE CPR GT Clutch suit 4-stroke. Suits Standard 19mm Drive Shaft (3/4") as used on most 6.5hp engines. This is a FULLY ADJUSTABLE Race ready twin shoe clutch. Engagment RPM can be adjusted with our NORAM GE spring range from 1820RPM through to 4320RPM. Read the engagement speed and rpm adjustement guide to select the correct springs and engagement settings here: https://www.cutpriceracing.com.au/store/Page62/ Complete unit with Drum and Clutch. Assembled ready-to-go. Length of inner shaft ~59mm - requires approx 56mm long shaft. Approx. diameter of body of clutch = 94mm
PACKAGE INCLUDES:Includes drive sprocket teeth number as per title. Includes 102L chain. Includes Rear Sprocket (#35) - your choice of teeth. Includes Key to suit 3/4" output shaft (19.05mm) DEFAULT UNIT SPECIFICATON:If you do not change any of the shoe or spring choices, the default unit has an RPM engagement speed of approximately 2000rpm which is ideal for most engines used in racing environments as well as engines used for recreational purposes. For modified race engines, you may required a higher rpm engagement speed. Engagement speed can be set from Very Smooth Gradual engagement with high inertia starts through to Rapid engagement with low inertia starts.
OPTIONS:SPRING TYPE: Choose your Spring type in the configuration wizard.Listed springs show rpm engagement with heavy shoes (H####) and light shoes (L####). Only Heavy Shoes are available. Springs determine the RPM engagement speed based on the shoe weight. NOTE: Purple springs may be noisy when in use due to the physical size of the spring - they will contact the drum. After a short period of use the noise should become quieter or disappear. It will not affect the opertaion of the clutch. REAR SPROCKET SIZE:Choose your sprocket size from all available sizes from 53T through to 85T
LEARN HOW TO DISASSEMBLE, ASSEMBLE & SERVICE YOUR CLUTCH
NOT SURE HOW TO BUY THIS ITEM? Click here to read our simple walk-through guide.
SKU | CGTSC3512 | |
Base product price: |
$179.00
including GST 10% |
