Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: Tillotson RK114HL Overhaul Kit with New Welsch Plug & Pop Off Spring suitComer S80 SW80 Carb
Genuine Tillotson Carburettor overhaul kit (seal kit) as pictured.
This is the COMPLETE overhaul kit, not the standard kit, or the diaphragm only kit.  Make sure you get all the parts you need, rather than scratching your head wondering where they are when you pop the top off your carb.
Suit COMER S80 SW80 Tillotson Carbies.
THIS MODEL INCLUDES THE POP-OFF SPRING
INLCUDES POP-OFF Spring.
INCLUDES Large Welsch Plug.
I BET YOU WON'T FIND A CHEAPER ORIGINAL TILLOTSON OVERHAUL KIT IN AUSTRALIA!
Please note: This is the ORIGINAL Tillotson Part - NOT A CHEAP IMITATION.
Does your carbie seal properly? Do you hold pressure on pop-off? If you don't, or you're not sure, you need to replace your needle. Cheap and effective way to maximise horsepower and correct starting problems.
Genuine Tillotson Carby RK-114HL Overhaul Kit with Large Welsch Plug & Pop Off Spring suit Comer S80 SW80
SKU RK114HL_PLUS
Regular price: $28.05
Price with FREE DELIVERY: $24.95
