Home :: Racing Simulator Parts & Retro Computing :: Steering Wheel - Simxperience Accuforce Pro V1 - Direct Drive (New old stock)
This is the latest model Accuforce Pro V1.  Brand new.  Has been fitted to a demo rig for display purposes only - steering wheel has not been used and was taken out of the packet once for pictures.  Has been sitting in box ever since.  All accessories supplied as per brand new unit.
This is the last of the final revision of the first generation - with the higher quality motor housing - a tougher and heavier unit than the new model with all bugs ironed out.  Uses a cable from the motor to the wheel the same as the new V2 to avoid problems with the quick release connector.  These are no longer available, so not only will you get this one sent immediately and at your house quicker than ever, but you'll also get a quality unit without any of the teething problems of the first run of new generation wheels.
Watch a review on the wheel here:
https://www.youtube.com/watch?v=qd88Ome9dRg
The AccuForce Pro is the most realistic, rugged, and beautiful FFB available on the market today. It is an extremely powerful and accurate direct drive system complete with motor, motor enclosure, controller, wheel, wheel button box, quick release, paddle shifters, mounting hardware and much more.  Being direct drive, means there are no gears or belts to cause any lag in the system, creating a 1 to 1 relationship between actions sent to the motor and what is felt in the driver’s hands.
The SimXperience AccuForce is a professional racing simulation steering system tailored to meet the needs of the most demanding sim racers and sim drivers by exceeding the specifications of existing high end wheels. When combined with today’s best racing simulation games, the AccuForce Pro is as close as you can get to driving the real thing and is delivered in a convenient, ready to run, plug-n-play package.
The key to its incredible realism is the groundbreaking direct drive motor control system. SimXperience has engineered an integrated motor controller / PC interface as opposed to communicating between two different circuit boards as is common in the industry. This allows the AccuForce to provide lower latency, better response and more accurate detail reproduction than competing direct drive systems. Combined with a motor that's specifically designed for racing simulation, the AccuForce system provides the best possible balance of torque, response and most importantly, fidelity and linearity. The end result: a driving experience that's second only to the real thing.
The AccuForce Pro also comes included with a FREE copy of the SimXperience Commander 4 software, offering a full range of tunable effects for the wheel as well as SimVibe (physics based vibrational feedback software), In-Game On-Screen display of customizable virtual gauges and dashboards, in-game motion adjustments, car & track specific motion profiles, profile sharing, telemetry logging and analysis and much more.
The AccuForce force feedback system provides a whopping 13Nm sustained torque with 0 heat fade, 2000Hz communication rate via SimXperience Dual Stream Technology, integrated slip rings providing infinite wheel rotation, robust tuning capability, a 3-Port Usb Hub, and expansion ports for additional displays, buttons, pedals, and rotary encoders.
Display Model
SKU SIMAFP
Price with FREE DELIVERY: $2999.00
