Home :: Axles & Parts :: 30mm :: Shaft-less 30mm Axle Kit 6mm Keyway Black / Silver (Without Axle Shaft)
Suits 2 and 4 stroke karts.
SHAFTLESS (Without shaft) 30mm AXLE ASSEMBLY.  EVERYTHING you need to bolt-on and go - including ALL the nuts and bolts WITH ANODISED COUNTERSUNK WASHERS!  This is a dream price!
1x 30mm Anodised Brake Hub
1x 30mm Anodised Sprocket Carrier/Hub
2x 30mm Low Friction Sealed Bearings
2x 30mm Anodised Self-aligning bearing carriers
2x 30mm Anodised Wheel Hubs
6x High Tensile Square Head bolts for Wheel Hubs.
30mm low friction free-spin bearings
Self-Aligning Bearing Flange/Holder/Cradle complete with 30mm Low Friction Race Bearing installed.
6mm Keyway
Length: 50mm + 7mm Flange
Bolts, washers & nuts included - standard thread
6mm Keyway
SKU AXSLC3K
Regular price: $472.62
Price with FREE DELIVERY: $249.00
$24.90
