INCLUDES 2-Digit 2-pack of numbers and backgrounds. 2 backgrounds (yellow or white) + 4 numbers (black or red) - 2x 2 digits. Choose the colour of your background + numbers, and two digits below.
*New Model Side Pods set. Can be used for both 2 stroke and 4 stroke kart applications.
Suits newer model karts with straight (90degree perpendicular) sidepod bars. Can be easily modified to suit older karts.
Kit comes with both sidepods.
Dimensions:
Sidepods - Length = 600mm, Width(at centre) = 180mm, Height = 200mm, Front cowling adds 95mm width to sidepod just behind front wheel.
Dimensions of sidepod picture:
SA - distance from divet to edge of front of sidepod = 70mm
SB - distance from divet to front bolt hole centre = 35mm
SC - bolt hole centre to bolt hole centre = 457mm
SD - rear bolt hole centre to rear of pod = 55mm
SE - Total length of sidepod = 617mm
SF - distance from rear bolt hole centre to centre of divet (cutout for bar) = 75mm
Brand New. *New Model SidePods set - Suits 2 stroke and 4 stroke karts.
