Home :: Brakes & Parts :: Hydraulic :: Hydraulic Brake Kit (Pro Race Type) including Master & Calliper (1050mm Line)
BRAND NEW Hydraulic Brake Calliper and Master
NEW MODEL
This is the NEW CPR PRO-RACE hydraulic brake assembly.  It has been completely re-designed and overhauled from our old model.  This kit has been professionally designed by a sports brake company and provides superior smooth trouble-free operation with the same fantastic benefits such as low price and flexibility of connection.  Plus we've provided a template for a bracket so it's perfect for a project.
DESIGNED FOR RELIABILITY
Our brake systems offer premium quality.  Designed and built by a reputable brake company, the CPR hydraulic brake system stops effectively and reliably.
PREFERRED BY RACE KARTERS
In blind tests conducted in QLD, race karters have stated they prefer the feel and consistency of CPR Race Hydraulic brake kits over the competition.
SUITS 4-18mm DISCS
Configured out of the box for use with 4-6mm discs, the CPR calliper can be spaced to suit up to 18mm discs with optional spacers, offering full compatibility with all popular OEM disc systems.
PRE-BELD, READY TO RACE
Our CPR hydraulic brake systems come pre-filled with hydraulic fluid, ready to bolt-on and use.  Often no bleeding is required before use!
Direct connection for CPR chassis.
The CPR PRO-RACE assembly has considerably more stopping power and much larger pads compared to our recreational set (BKHC01).  This kit will work on larger discs (like 12 or 18mm width discs) effectively.
Approx 105cm long line.
Suits up to 6mm disc in standard form using the supplied bracket and bolts.
*Suit up to 12mm disc if fitted with optional spacers/washers (not supplied)
*Suit up to 18mm disc if refitted with longer bolts (not supplied).
^Mounting bracket supplied to suit 63mm brackets, or remove bracket and mount each calliper either side of the chassis bracket.  (When used in this configuration minimum disc size is 6mm+Bracket width)
A= 57 or 63mm^, B=Up To 18mm*, C=33mm
- 1x Dual hyrdaulic line Master Cylinder
- 1x Dual line calliper with 67mm wide pads
Designed for use with DOT3 or DOT4 fluid.
 Need to make a bracket for these?  There is now a template for bracket in pictures above.  (Template not included in package - downloadable only)
SKU BKHC04BKT
Price with FREE DELIVERY: $199.90
$69.00
$16.65
Connector Splitter T for Brake Line
Connector Right Angle L for Brake Line (oliveless) Connector Splitter T for Brake Line
$9.95
$16.95
Bracket for Brake Calliper suit CPR BKCH04 & BKCC02 Brake Kits
Brake Line Hydraulic 6mmOD 4mmID per Metre Bracket for Brake Calliper suit CPR BKCH04 & BKCC02 Brake Kits
$7.95
$24.90
Hydraulic Brake Piston Kit suits BKHC04 Master Cylinder WITH SEALS
$24.95
