Home :: Clutches :: Go Kart TWIN DRIVE Torque Converter JACKSHAFT ONLY 15.875mm 5/8inch with keyway (Suits CPR Torque Converters TCC121 & TCC1234)
NEW
TWIN DRIVE external sprocket extended TCC12## (CPR TORQUE CONVERTER) jackshaft.
5/8" to suit our TCC121, TCC1234 range of torque converters.
THIS IS THE JACKSHAFT ONLY - DOES NOT INCLUDE PLATE, DRIVEN PULLEY OR SPROCKET.
INCLUDES:  Jackshaft, stub-key for outboard sprocket, and retainer circlip.
Our new TWIN DRIVE system allows you to locate a sprocket INBOARD (between the sideplate and the driven pulley) or OUTBOARD (on the outside of the jackshaft) to locate the sprocket next to the rear engine-side wheel, rather than inboard between the inner bearings behind the seat.
This gives you a much easier way to mount a 4-stroke engine to a 2-stroke chassis! No more bending and welding - use your existing keyway in your axle! *Note, the engine may need to be shifed a little furter outboard to clear the outermost bearing bracket.
BRAND NEW
SKU JSKTDC
Price with FREE DELIVERY: $100.00
