Awesome new budget-focussed cylinder head temp gauge - no longer do you need to pay $500 to save your engine from costly overheating damage.
When running an air cooled engine, temperature can build up too fast to feel when you're rushing around a track at breakneck speed - you need a reliable solution to alert you to overheating. Overheating an air cooled engine can quickly result in melted pistons, damaged rings and ruined cylinders - lots of costly damage you could avoid by installing this awesome new piece of equipment!
NEW Front-Mounted Buttons RESETTABLE MAX TEMP FUNCTION! PLUS SETTABLE TEMPERATURE ALERT!
This is the latest model. NOW WITH LARGE DISPLAY AND BACKLIGHT!
This model suits both 2 & 4 stroke karts.
COMPLETE EVERYTHING you need to bolt-on and go - including cylinder head temperature sensor - simply remove spark plug and re-install with sensor lead before spark plug.
1x up to 300 degrees C Temp Gauge with TEMP ALERT, MAX-TEMP Recall.
1x Backlight system
1x Sensor with clip/connector (Sensor Inner Diameter 14mm)
Sensor line length 60cm
1x Battery
1x Instructions Set
Front Mounted adjustment buttons. Access features and readouts on-the-go
LARGE 5 digit LCD screen
BACKLIGHT
Minus 20C to 300C sensitivity
OVER-TEMP ALERT
Maximum Temp Recall
Current Temp
waterproof level IP65
NEW! SAVE YOUR AIR-COOLED ENGINE FOR JUST $79! NEW CPR GT CYLINDER HEAD TEMP GAUGE!
2-STROKE AND 4-STROKE AIR COOLED COMPATIBLE!
If you've got a KT100S or any other air cooled engine, and you've seized it due to lean-out you'll know just how quickly that can happen - in the course of one long straight often. If you're running speedway it's an even bigger problem with revs constantly high.
Rebuilding an engine due to lean-out and melted pistons can cost upwards of $500 depending on who's doing it for you - parts run $200-$300 easily and that's if you can save the bore.
THIS GAUGE WILL SAVE YOU!
- TEMP LIMIT ALERT - User Settable
- LARGE BACKLIT DISPLAY
- MAX TEMP RECALL
- REPLACABLE BATTERY
- WEATHER PROOF
- INCLUDED UNDER-PLUG TEMP SENSOR
With it's unique temperature alert, backlight and Maximum Temp Recall you'll be in the know at all times - and you can keep a close eye on what your engine is doing while you're driving.
You can even tune your engine using the temp gauge!
The other options for temp gauges on the market are costing in excess of $500 - but with this neat little unit you'll be paying less than $100 to be fully protected!
Is it really worth not having a temp gauge at this price?
Designed for go karts.
FAQ - TEMP SENSOR DAMAGE
. Several factors can cause them to fail including the following:
1. Over-Tightening the spark plug
a. If the plug is tightened down too much, the ring can easily twist and break. One solution can be to use a copper grease and a thin thrust washer between the ring and the base of the plug.
2. Multiple removal and installation of the plug
a. This is a common issue where plugs are being read. Unfortunately cylinder head temp sensors have the inherent issue where they are not designed to have plugs tightened and removed multiple times. Ideally it should be a set and forget solution. However, in practice this is hard to achieve. We recommend using copper grease and a thin thrust washer between the ring and the base of the plug.
3. Modifying the orientation of the fly lead from the sensor ring
a. Sometimes it may be desirable to twist or bend the sensor ring fly lead to avoid fins or other obstacles, or to try to avoid hot surfaces. While this is not recommended as it can damage the sensor, if you are doing this it is best to heat the ring prior to trying to bend. Bend the lead slowly and gently until it has reached the desired shape. It is definitely possible to break the lead this way so take your time. Damage in this way is not covered under warranty.
4. Surface inconsistency (divots/damage/dags/lips/debris/other sharp protrusions) on cylinder head, plug thread, or plug base
a. Check your head, plug thread and plug base that they are all smooth and free from any debris that may catch on the sensor ring – this can rip the sensor ring easily.
5. If all else fails
a. CPR Kart Parts carries replacement sensor rings for all CPR temp gauges which can be found in the store in the gauges section.
