Home :: Engines, Carbs & Parts :: Engines :: Cylinder Head Complete GT-RACE GX200 BIG VALVE head SHAVED 30Thou 13.1 Comp. Race Port & Polish
GT-RACE Cylinder Head Complete suit GX160 & GX200 Clone or GX200(including CPR engines).
THIS MODEL IS 30THOU SHAVED GIVING 13:1 COMPRESSION
The GT-Race Big Valve GX200 head will substantially increase your horsepower by up to 25% depending on existing modifications.  That means you'll improve a 14hp engine up to nearly 18hp with the right setup!
- BIG STAINLESS STEEL RACE VALVES AND CUSTOM VALVE SEATS
With 28.5mm intake valve and a 25mm exhaust valve you'll get substantially improved flow, leading to improved performance.  This is coupled with our GT-RACE 3 angle valve cut provides unrivalled performance advantage over standard valve seats.
- GT-RACE HIGH PERFORMANCE PORTING & POLISHING
With highly reputable high performance porting as used on winning race engines at venues such as Ipswich, you'll be certain your flow is maximised and power output as high as possible from your head.
- GT-RACE HIGH PERFORMANCE VALVE SPRINGS
Maximum RPM can be achieved using these special 36lb valve springs suiting all cams up to 275.
- GT-RACE PERFORMANCE MILLING 13:1 COMPRESSION WITH THIN-STYLE GHLA01 HEAD GASKETS
THIS HEAD OFFERS LESS COMPRESSION THAN THE GX160 MODEL BUT MORE RELIABILITY.  INCLUDES 0.030" milling.  This GT-RACE performance head will provide 13.1:1 compression using thin style head gaskets (such as the GHLA01).  Recommended to use the Fibre or MLS gaskets.
CPR's new GT-RACE series selects our performance components to suit competitive racing go-karts for track competition purposes.
Uncompromising quality at the most affordable price. Make no mistake though, CPR GT-RACE products are premium quality.
HeadTearDownGuide
SKU ECH20UG
Regular price: $1022.50
Price with FREE DELIVERY: $699.00
