Home :: Axles & Parts :: 40mm :: Complete Racing Mower 40mm Axle Kit 8mm Keyway Blue with Weld-on Brackets and 4-Stud Wheel Adaptors (With subs Silver Bearing Hangers)
*THIS KIT COMES WITH SILVER BEARING HUBS*
CPR Race Mower kits include everything you'll need to quickly, easily, and correctly install the rear drive axle assembly.  Includes weld-on brackets and hub adaptors to suit most 4-stud mower rear wheels.
INCLUDES 4-STUD PCD Adaptors to fit most common racing mower rear wheels.
1x 40mm Axle Shaft
2x 4x110mm PCD Hub Adaptors (Steel - High Strength)
F = ~296mm
WHEEL HUB ADAPTORS
SKU AXMP40B_S
Regular price: $1524.47
$24.90
$21.95
