BRAND NEW FULL SET of 3-Spoke Mag-Style Dry Slick Alloy Rims
REAR
210mm Wide
5" Diameter
PCD: Holes are set 50mm apart from each other and 29mm from the centre
Suit DRY SLICK TYRES. Wet tyre can be fitted with a little ginning around but will result in slightly smaller diameter wheel.
FRONT
17mm Bearings installed to suit 17mm Stub Shafts
Offset
130mm Wide
High Quality turned aluminium alloy.
