Home :: Clutches :: Clutch Friction Plate & Pressure Plate kit for Wet Reduction Box 2:1
Full set of replacement friction plates to suit 2:1 Reduction box found on 6.5hp and 5.5hp and clone engines - measurements indicate that it should be compatible with 9hp engines but it's worth checking your measurements against the ones below to confirm before purchasing.
ONE KIT.
FRICTION DISKS DIMENSIONS:
Diameter (outer) is 106.90
Inside diameter (outer edge of teeth) approx 58mm
Pins PCD ~65mm
Thickness approximately 3.85mm
TRANSFER PLATE
Inside diameter approx 78mm
Outside diameter (including tangs) approx 118mm
Includes friction plates, transfer plates and pressure plate as per picture.
SKU CWTRK1
Price with FREE DELIVERY: $59.00
$32.95
$26.95
