Home :: Clutches :: Race GE & GT Range :: Clutch CPR GT-RACE Series 35 Pitch 15 Tooth 19mm (3/4") bore + Chain + Sprocket + Key
COMPLETE KIT WITH EVERYTHING YOU NEED INCLUDING CRANKSHAFT KEY!
Read the engagement speed and rpm adjustement guide to select the correct springs and engagement settings here: https://www.cutpriceracing.com.au/store/Page62/
PACKAGE INCLUDES:
Includes drive sprocket teeth number as per title.
Includes 97L chain.
Includes Rear Sprocket (#35) - your choice of teeth.
Includes Key to suit 3/4" output shaft (19.05mm)
DEFAULT UNIT SPECIFICATON:
If you do not change any of the shoe or spring choices, the default unit is fitted with light shoes and has an RPM engagement speed of approximately 2450rpm which is ideal for most engines used in racing environments.  This combination gives you a boost off the line, and less bogging down in the corners.
OPTIONS:
SHOE WEIGHT:  You can also choose your Shoe weight in the configuration wizard.
Heavy shoes are recommended for stock and mild tune engines, giving a better bite at lower rpm for better use of low-down torque.  Light shoes are recommended for heavily tuned engines where torque is produced much higher in the rev range.  This gives more slip down low to allow the engine to reach the high torque section of the power curve.
SPRING TYPE:  Choose your Spring type in the configuration wizard.
Listed springs show rpm engagement with heavy shoes (H####) and light shoes (L####).  Springs determine the RPM engagement speed based on the shoe weight.
REAR SPROCKET SIZE:
Choose your sprocket size from all available sizes from 53T through to 85T
LEARN HOW TO DISASSEMBLE, ASSEMBLE & SERVICE YOUR CLUTCH:
Visit our forum and read our guide here:
http://cutpriceracing.com.au//phpbb3/viewtopic.php?f=14&t=850
GTClutchServiceGuide
GTClutchChoiceGuide
SKU CGTSC3515
Base product price: $179.00
