Home :: Chassis Parts & Bare Frames :: Crash bars and linkages :: Chassis Underside Frame Protector (Kerb Rider) Set (3pcs)
BRAND NEW set of 3 chassis underside protectors
THIS IS THE NEW MODEL - picture showing attachment to kart is a picture of the older model, the new model now has 3x sections of the same size and dimensions.  Instruction leaflet picture shows old model, but the assembly/attachment is done in exactly the same way.
INCLUDES FULL SET OF MOUNTING BOLTS. (M6x25 Countersunk x6pcs)
Precision cut nylon set.  Designed to attach to floor pan, overlaping chassis rails to protect the kart against damage from driving over kerbs or infield and other objects.
note: pre-punched countersunk holes are not fully drilled through.  If you choose to use other locations that is perfectly fine.
Dimenions:
All 3 sections of this new model are identical:
W - 170mm (Width),
Y - 70mm (total Height front to back),
no dimension shown: 10mm (Thickness maximum of mount section)
B - From rear of straight edge to centre of countersunk punch - 20mm
H - From centre of countersunk punch to centre of countersunk punch - 100mm
K - From centre of countersunk punch to edge - 36mm
X - Radius of corner (from beginning of taper to the edge of the material)  - 30mm
Z - Length of flat side of material - 110mm
Width of chamfer on bottom side is 30mm.
See picture above for fitting directions.
SKU SCPS02
Price with FREE DELIVERY: $89.50
