Home :: Axles & Parts :: 40mm :: 40mm AXLE UPGRADE - Brake Disc Ventilated 12mm - SUITS AXCC408
THIS PART IS AN UPGRADE PART ONLY.  YOU MUST BUY AN AXLE ASSEMBLY TO PURCHASE THIS PART.
TO UPGRADE OUR 40mm AXLE ASSEMBLY KIT AXCC408:  Simply purchase the axle kit & then purchase this upgrade to move up to 12mm ventillated disc.
UPGRADE 40mm AXCC408 Axle Assembly to Ventillated Brake Disc with Hub / Carrier.
If you are looking for this part as an individual purchase, please view our Axles & Parts > 40mm section.
Suits axle diameter: 40mm
Keyway size: 8mm
CROSS DRILLED (SLOTTED) Brake Disc
Complete with standard 6-bolt brake hub
PCD 113x6 - bolt-to-bolt distance = 56mm
THICKNESS
12mm
And includes with Bolt Kit consisting of:
6x M6 High Tensile Bolts, Washers, & Nylocs
UPGRADE ONLY
SKU AXCC408U12
Price with FREE DELIVERY: $109.00
