Home :: Engines, Carbs & Parts :: Engines :: 4-Stroke Engine LIFAN OHV 3.5hp 98.5cc Complete with 11T #35 Clutch and Throttle Cable
Are you looking for a simple & easy solution to powering a midget, rookie or kids go kart?  Ideal starting point for racing or recreational use, our LIFAN Honda Clone engine is one of the best built, most reliable available in Australia.  We buy the best quality clone available today with quality automotive grade components inside.  It comes complete, ready to run with throttle cable and clutch already attached.  All you need to do is mount it to your frame - can be easily adapted to any 2-stroke mount with an adaptor plate.
Buy the time you buy a cheap clone, a clutch and all the mounting equipment, as well as a throttle cable and mounting equipment, as well as the time and headaches required to get it all to work, you'll be wishing you bought one of our simple 'ready-to-go' engines!
Lifan equipment will keep you running. All Lifan engines are Industrial Grade and feature cast iron sleeves, automotive grade rods, pistons, rings, crankshafts, valve and valve springs.The Lifan Overhead Valve (OHV) design provides better fuel efficiency, quieter operation, and longer life. The 3.5 HP 98CC Horizontal Shaft Engine is ideal for go kart use.  The Overhead Valve (OHV) design provides fuel efficiency, quiet operation, and a long life. The engine features a horizontal-shaft design for go-kart use.
Engine overall dimension: 280x300x310mm
56 mm x 40 mm bore/stroke
0.6kg-m .max torque Horizontal output shaft (5/16 ~16mm)
3.5 HP Max @ 3600rpm
~2L fuel tank capacity offers long run times
Force-Air Cooled
MFG Brand Name : LIFAN
Base plate mount hole location - 4x bolts - 61.5mm x 102.5mm
This unit is supplied with Throttle Cable to suit all go-kart pedals, Toolkit and owners manual with all setup details including valve clearances etc.   A comprehensive package.  Go racing on the cheap!
Need an owners manual?  Download one by clicking here.
SKU ENCL35
Price with FREE DELIVERY: $349.00
