Total Paint Care
Racespray, Showspray & Total Paint Care
Total Paint Care
Postby cutpriceracing » Sun Aug 21, 2016 2:53 am
Total Paint Care
YOU WANT that deep showroom SHINE but you don’t want all of the back-breaking sweat pouring hard work needed to apply polishes and waxes. In fact, you’re on a tight schedule and you don’t have very much time at all, let alone enough to detail the car.
Sound like you?
Then GLISTEN has the product you’re looking for!
Total Paint Care will out-shine with virtually no effort required at all - seriously! One easy effortless step will clean, polish, shine, and protect your duco against fading, bird and bat droppings making your car a breeze to clean later! You don’t even need to clean it first. No sweat!
It’s safe for all paint types including 2-pack, acrylic, enamel, clears, chameleons, harlequins and pearls. Why? Because it won’t remove any paint and it can’t penetrate the paint surface.
Zero preparation. Deep cleansing system. Non abrasive polish. Carnuba ‘Hard as Concrete’ protection. Superb clarity sheen in less than 15 MINUTES for an average car.
Re: Total Paint Care
TOTAL PAINT CARE APPLICATION INSTRUCTIONS
Surface must be completely dry. A cool surface is best - for warm or very warm surfaces treat
Find a shaded area free from wind if possible. GLISTEN Total Paint Care is misted on so wind will cause wastage.
You do not need to wash the vehicle first but heavy soiling such as clays, tars and other clumps of mud and dirt should be removed prior to treatment.
Step 1. Mist-on & Wait
Shake the bottle for 10-15 seconds to ensure ingredientsar completely mixed.
Mist-on sparingly directly onto the paint surface.
NOTE: Cover a small section at a time, approx one panel in acool dry environment. Reduce to 1/2-1/4 panel in warm-hotconditions or when in direct sunlight.Step 2. Wipe one way
Using a clean dry 100% cotton cloth, wipe one way onlyover the area where GLISTEN Total Paint Care has beenapplied. Turn the cloth regularly.Step 3. Buff to a brilliant shine
Use a second clean dry 100% cotton cloth to buff the samearea to a brilliant shine. The luster is a result of the protective layer which canlast up to 2 months.
NOTE: Because the advanced formula in GLISTEN Total Paint Care does notremove or damage your paint, you can use it as often as you like. In-fact, themore often you use Total Paint Care the less you will require and the more it willprotect and improve the appearance of your vehicle.
Postby cutpriceracing » Mon Mar 13, 2017 5:31 am
Return to Glisten Polish
