Showspray
Racespray, Showspray & Total Paint Care
Showspray
Postby cutpriceracing » Sun Aug 21, 2016 2:51 am
ShowSpray
Ever arrived at that show n shine, cruise day, or other important event and noticed you’d driven through mud? Or worse, parked under a tree and recieved sap or bird droppings on your freshly detailed paint?
YOU WANT to be able to remove debris and gritty spatter without scratching your paint, or otherwise damaging your detailing work. right?
Sound like you?
Then GLISTEN has the product you’re looking for!
ShowSpray is the perfect ’show day’ partner. It’s Scratch-Free formula is capable of removing most road related grime and contamination including gritty substances without scratching paint or removing the shine of freshly detailed paint.
Will out-shine with virtually no effort required at all - seriously! One easy effortless step will clean, polish, shine, and protect your duco against fading, bird and bat droppings making your car a breeze to clean later! You don’t even need to clean it first. No sweat!
Because ShowSpray uses the same fundamental technology as the extremely popular ‘Total Paint Care’ product, it’s safe for all paint types including 2-pack, acrylic, enamel, clears, chameleons, harlequins and pearls. Why? Because it won’t remove any paint and it can’t penetrate the paint surface.
100% Safe. Quick. Convenient. Show-stopping shine!
Re: Showspray
COMPLETELY SAFE SPECIALTY FINISH POLISHING
- Concerned about the thickness of your paint?
If you are worried that you only have a small amount of paint left on the car, try polishing with GLISTEN SHOWSPRAY. Some stains may not be removed, but unlike cutting compound you won’t take any paint off so it’s completely safe to try.
- Want to remove stains and grime from specialty finishes?
This process can also be used with specialty finishes where clear coats are precious and where removal can affect the visual dynamics of the specialty finish.
- Want to remove JUST the oxidised portion of your paint?
You can also use the polishing process to remove oxidised paint, and the best part is that GLISTEN SHOWSPRAY will only remove the oxidised component of your paint, not the good condition paint beneath like cutting compounds will.
- Want to polish EDGES without removing paint?
Edges and tight curves are prone to paint removal when using cutting compounds. It’s quite easy to accidently ¡¥Go Too Far’ when using an abdrasive polish and remove paint layers or even primer. GLISTEN SHOWSPRAY can’t remove paint so it’s perfect for edges.
HOW TO DO IT:
If the car is dirty, follow the standard instructions for cleaning the vehicle before using GLISTEN SHOWSPRAY to polish. Click the button below to go directly to the cleaning instructions.
STEP 1
Only perform polishing in a cool, dry, wind-free area. If the ambient temperature is high, apply to around half the quoted area below.
Mist GLISTEN SHOWSPRAY onto the section where polishing is to be performed. Apply to a small section at a time only. Approx. 20cm square is the about the maximum you should attempt to polish in one mist assuming the conditions are optimum (room temperature).
Spray a little more than usual to ensure enough clay particles are present.
STEP 2
Applying a light to medium pressure, massage the product into the panel. Once the product has dried and is glossy to view, re-apply as per step 1 until the desired result is achieved or until no improvement in the finish is seen.
You may not be able to remove some stains or grime if they have absorbed into the bonded paint.
COMPLETELY SAFE SHINE & DRIVE!
Just want to shine her up? GLISTEN SHOWSPRAY will bring out a deep showroom shine and protect your car for up to 2 months. And it’s completely safe for specialty finishes and all paint types because it doesn’t penetrate the paint surface.
-REDUCE FADING-REDUCE CORROSION-REDUCE STAINS
If you clean the vehicle using GLISTEN SHOWSPRAY then you’ve already performed this very important step. If you use another product to clean, or alternatively you want to add further gloss and shine to your finish, follow the steps below.
STEP 1
Mist-on a small 20×20cm section very sparingly. Use very little product for best results and cost-effectiveness.
Allow to haze slightly, wait a couple of seconds.
STEP 2
Buff quickly and watch your finish shine brightly.
Re: Showspray
Postby cutpriceracing » Mon Mar 13, 2017 5:32 am
Return to Glisten Polish
Users browsing this forum: No registered users and 4 guests
