Racespray
Racespray, Showspray & Total Paint Care
Racespray
Postby cutpriceracing » Sun Aug 21, 2016 2:49 am
RaceSpray
NEW! Hi - Tech Competition Cleaner and Protectant.
RACESPRAY is here!
Designed exclusively for competition use, RaceSpray harnesses the power of nearly 30 different ingredients to safely clean, degrease, and protect against debris commonly encountered on Motorsport Curcuits.
Developed in the USA, RaceSpray has been tried and tested for nearly 10 years under an alternative product name. GLISTEN has now acquired this incredible product to offer Australians a new level of convenience in motorsport.
RACESPRAY will help remove and protect against:- Tyre marks- Oil- Grease- Chainlube and other lubrications- Water (helps stop water entering exposed bearings)- Small fuel spills- Dirt- Dust- Oily fumes
RACESPRAY is 100% SAFE to use on any non-porus surface such as:- Plastics- Stickers- Paint- Fibreglass- Metals and Alloys as well as Anodised Alloys- Rubber components (except tyres as product will cause loss of friciton)- Glass
RaceSpray is perfect to use in the Pits to clean and protect, or aid visual inspections of wear and breakage. RaceSpray will also come in handy on rainy days where it can be used to protect visors, windshields, and other visual shields against water droplets by resisting and driving water away.
Re: Racespray
RACESPRAY APPLICATION INSTRUCTIONS
Surface must be completely dry. A cool surface is best - for warm or very warm surfaces treat
Find a shaded area free from wind if possible. GLISTEN RACESSPRAY is misted on so wind will cause wastage.
You do not need to wash the surface first but heavy soiling such as clays, tars and other clumps of mud and dirt should be removed prior to treatment.
Step 1. Mist-on & Wait
Shake the bottle for 10-15 seconds to ensure ingredientsar completely mixed.
Mist-on sparingly directly onto the surface.
NOTE: Cover a small section at a time, approx one panel in acool dry environment. Reduce to 1/2-1/4 panel in warm-hotconditions or when in direct sunlight.Step 2. Wipe one way
Using a clean dry 100% cotton cloth, wipe one way onlyover the area where GLISTEN RACESPRAY has beenapplied. Turn the cloth regularly.Step 3. Buff to a brilliant shine
Use a second clean dry 100% cotton cloth to buff the samearea to a brilliant shine. The luster is a result of the protective layer which canlast up to 2 months.
NOTE: Because the advanced formula in GLISTEN RACESPRAY does notremove or damage paint/plastic etc, you can use it as often as you like. In-fact, themore often you use RACESPRAY the less you will require and the more it willprotect and improve the appearance of your vehicle.
Re: Racespray
Postby cutpriceracing » Mon Mar 13, 2017 5:32 am
Return to Glisten Polish
Users browsing this forum: No registered users and 4 guests
