Engine Warranties
Engine Warranties
Postby cutpriceracing » Tue Jan 26, 2016 10:04 pm
ALL Engines Warranty
Cut Price Racing engines are sourced from the most reliable and highest quality factories to provide you with a reliable and cost-effective, simple to use power plant for recreational purposes. Our engines are designed to perform for very long periods of time without faults as long as they are used responsibly and follow our standard warranty terms below:
OIL - Each 200cc engine must be filled with clean 5/30W oil. Preferably not fully synthetic oil. Fully ynthetic oil willl reduce the lifespan of the engine. Oil must be changed regularly - dirty oil can block the oil feed for the connecting rod and seize the engine.
FUEL - Only use clean unleaded fuel. No ethanol blends. Premium unleaded is optimal.
MODIFICATION - This warranty is void if the engine contains any modification in addition to factory/supplied specification. Opening the crankcase or any other component will void warranty.
EXCEPTION - This warranty is void if engine has been used for racing.
EXCEPTION - This warranty is void if fuel blockages are caused by customer fuel or filling equipment (dirty funnels, storage containers, debris falling into fuel tanks etc)
Cut Price Racing will warrant all engines Dead On Arrival (DOA) where the engine supplied does not start or operate correctly and has been filled with the correct oil and fuel specified above where the engine has been operated within 14 days from receipt of the engine by the delivery company used to deliver the engine to the customer.
Governed Engines Warranty
Cut Price Racing will warrant all governed engines where the engine supplied does not operate correctly and has been filled with the correct oil and fuel specified above where the engine is within 90 days from receipt of the engine by the delivery company used to deliver the engine to the customer.
*Non-Governed Engines Warranty
*Non governed engines warranty does not cover RACE ENGINES - (Stage 1, Stage 2, Stage 3 engines)
EXCEPTION - This warranty is void if engine has been used for racing OR engine has been run at a higher rpm than 5000rpm.
Cut Price Racing will warrant all non-governed engines where the engine supplied does not operate correctly and has been filled with the correct oil and fuel specified above where the engine is within 30 days from receipt of the engine by the delivery company used to deliver the engine to the customer.
Race Engines Warranty (Stage 1, Stage 2, Stage 3 engines)
Cut Price Racing will warrant all governed engines where the engine supplied does not operate correctly and has been filled with the correct oil and fuel specified above where the engine is within 30 days from receipt of the engine by the delivery company used to deliver the engine to the customer.
*Note: This warranty is valid for engines intended to be raced, but that are faulty out of the box and have not actually been raced*
Return to CPR Sale & Privacy Policies
Users browsing this forum: No registered users and 15 guests
